tina5sdk-bsp编译报错
sun8iw20p1 compile all(Kernel+modules+boot.img) successful
INFO: build dts ...
INFO: Prepare toolchain ...
removed '/home/zm/tina5sdk-bsp/out/t113/evb1_auto/buildroot/.board.dtb.d.dtc.tmp'
removed '/home/zm/tina5sdk-bsp/out/t113/evb1_auto/buildroot/.board.dtb.dts.tmp'
'/home/zm/tina5sdk-bsp/out/t113/kernel/build/arch/arm/boot/dts/.board.dtb.d.dtc.tmp' -> '/home/zm/tina5sdk-bsp/out/t113/evb1_auto/buildroot/.board.dtb.d.dtc.tmp'
'/home/zm/tina5sdk-bsp/out/t113/kernel/build/arch/arm/boot/dts/.board.dtb.dts.tmp' -> '/home/zm/tina5sdk-bsp/out/t113/evb1_auto/buildroot/.board.dtb.dts.tmp'
'/home/zm/tina5sdk-bsp/out/t113/kernel/staging/sunxi.dtb' -> '/home/zm/tina5sdk-bsp/out/t113/evb1_auto/buildroot/sunxi.dtb'
INFO: build rootfs ...
INFO: build buildroot ...
./build.sh: line 12: $'\r': command not found
: invalid option 13: set: -
set: usage: set [-abefhkmnptuvxBCHP] [-o option-name] [--] [arg ...]
./build.sh: line 14: $'\r': command not found
./build.sh: line 24: syntax error near unexpected token $'\r'' '/build.sh: line 24:
make_ramfs_menuconfig()
ERROR: build buildroot Failed
INFO: build_buildroot_rootfs failed
执行./build.sh -d编译报错
