&disp {
disp_init_enable = <1>;
disp_mode = <0>;
screen0_output_type = <2>;
screen0_output_mode = <14>;
screen1_output_type = <1>;
screen1_output_mode = <4>;
screen1_output_format = <0>;
screen1_output_bits = <0>;
screen1_output_eotf = <4>;
screen1_output_cs = <257>;
screen1_output_dvi_hdmi = <2>;
screen1_output_range = <2>;
screen1_output_scan = <0>;
screen1_output_aspect_ratio = <8>;
dev0_output_type = <2>;
dev0_output_mode = <14>;
dev0_screen_id = <0>;
dev0_do_hpd = <1>;
dev1_output_type = <1>;
dev1_output_mode = <4>;
dev1_screen_id = <1>;
dev1_do_hpd = <1>;
def_output_dev = <0>;
hdmi_mode_check = <1>;
fb0_format = <0>;
fb0_width = <720>;
fb0_height = <480>;
fb1_format = <0>;
fb1_width = <1920>;
fb1_height = <1080>;
chn_cfg_mode = <1>;
disp_para_zone = <1>;
/*VCC-LCD*/
/* dc1sw-supply = <®_dc1sw>;*/
/*VCC-DSI*/
/* eldo3-supply = <®_eldo3>;*/
/*VCC-PD*/
/* dcdc1-supply = <®_dcdc1>;*/
&tvd {
tvd_sw = <1>;
tvd_interface = <0>;
tvd_format = <0>;
tvd_system = <0>;
tvd_row = <1>;
tvd_column = <1>;
tvd_channel0_en = <1>;
tvd_channel1_en = <1>;
tvd_channel2_en = <0>;
tvd_channel3_en = <0>;
/*tvd_gpio0 = <&pio PD 22 GPIO_ACTIVE_HIGH>;*/
/*tvd_gpio1 = <&pio PD 23 GPIO_ACTIVE_HIGH>;*/
/*tvd_gpio2 = <&pio PD 24 GPIO_ACTIVE_HIGH>;*/
/*tvd_power0 = "dc1sw"*/
/*tvd_power1 = "eldo3"*/
评论
请 登录后发表观点
暂无数据
- 积分
20 - 话题
5 - 评论
7 - 注册排名
1
